thealleyboy Posted January 20, 2004 Share Posted January 20, 2004 Trying to help a fellow Sube owner with a likely NSS problem via email. The car is an 85 GL 2wd A/T wagon. I'm thinking the NSS is located under the console assembly on that model, attached to shift lever. I'm guessing it's the thingy that makes that nice "click" as you move the shifter up and down. Does my memory serve me correct? I don't want to lead this person down the wrong path. It's too cold outside to be xperimentin'... thanks, John Quote Link to comment Share on other sites More sharing options...
calebz Posted January 20, 2004 Share Posted January 20, 2004 Yup, its under the console, part of the shifter assembly.. Found it when I had to bypass it for my 5 speed conversion. Quote Link to comment Share on other sites More sharing options...
thealleyboy Posted January 20, 2004 Author Share Posted January 20, 2004 Thanks Cal, Thought that's how it was routed thru the starting circuit... John Quote Link to comment Share on other sites More sharing options...
