head gasket corrosion pic
96 legacy sedan 2.2 164k
my nieces car,..I bought it for my son who is turning 16 in august
check out this section of the head gasket...corrosion..had more of a rust color before I power washed the engine
Anyone have an idea if this is a precursor to the gasket failing?
should I scrape it loose...spray a little wd-40 so maybe it does not keep corroding?
.....ok ...how do I attach an image?
EJ22 - highly unlikely the head gasket will fail unless the cooling system is improperly treated. the fluid isn't changed, properly burped, something leaks, radiator clogs and causes an overheat - along with t-stat, radiator cap, water pump, etc. i usually replace all that stuff to avoid leaks/overheats, except the radiators i usually just wait until they start leaking unless they're really bad shape. dont' overheat it and you won't have head gasket issues.
i guess you're talking about the external protrusion of the headgasket rusting? not sure what that means.
