May 23, 200916 yr no idea why just a couple days ago my car decided to throw me a new curve-ball -88 gl-10 turbo swapped 5 spd pb. when i turn off the car, the driver side not headlight but corner light stays on, as well as the pass. tail light. as an added bonus i've blown 5 fusible links since this started, any ideas where the gremlin may be hiding??
May 24, 200916 yr Is it possible your park light switch is on and you actually have two lights burned out? What was the car originally, did you just swap the tranny in or did you have to do a lot of other work?
May 24, 200916 yr Author ^^ Kicks self in rump roast repeatedly for being an idiot. you rock!!!! for the tranny swap i went form 3at, to the P/b 5 spd out of my old 91 loyale, wired the 4wd up, threw in the pedal assembly did some cutting etc, Viola! only took a day with two buddies and a case of mike's.
