May 28, 200916 yr Bad vibration under load and vehicle would not move foward one time recently. Auto AWD. Car's in nice shape but don't think i can take the time to change tranny. Knowledge lacking as well. Any thoughts on repair or value?
May 28, 200916 yr Bad vibration under load and vehicle would not move foward one time recently. Auto AWD. Car's in nice shape but don't think i can take the time to change tranny. Knowledge lacking as well. Any thoughts on repair or value? drain and refill the trans fluid with new, include a qt. of trans-x stop leak. search for it here and read. folks have had good luck with it on 99 auto trans. there is a seal that tends to leak, the trans-x helps. one of the threads is current. http://www.ultimatesubaru.org/forum/showthread.php?t=87708
May 28, 200916 yr Read the post "Fixed Trany delayed forward engagement." It is listed back a page or two on this forum at this time. That post specifically address the problem on 99 and 00 Legacys with auto trans. The Trans-X added to my car a year ago fixed the trany problem. Vibration under load may also indicate that you need to tune up your car with new spark plugs and plug wires.
