floortom Posted May 28, 2009 Share Posted May 28, 2009 after trying to find parts for this car, i'm considerting changhing the flywheel out of a wagon i got...why is the hatch 1" bigger than the wagon, if it's the bigger car? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 28, 2009 Share Posted May 28, 2009 It isn't - 80 through 82 used the 200mm clutch. 83 through 89 2WD's used the same 200mm clutch. It's the 83 and newer 4WD's that use the 225mm clutch. I have told you this - third time now. Call Discount Import Parts in Milwaukie or go to the dealer. This is not an unusual clutch - hell Autozone can get them easily. As for the interchangeability - the 200mm and 225mm interchange without issue. You have to use the flywheel, disc and pressure plate for the 200mm. Personally I throw the 200mm's in the trash as they are too small for a 4WD. GD Quote Link to comment Share on other sites More sharing options...
