January 22, 200422 yr I use my car for work, and do a lot of U turns, out of culdesacs and whatnot. The car has begun to shuddle pretty badly when powering through a Uturn, or any other sharp turn under power, and when I let off I hear this aweful grinding of metal on metal. Is this my CV joints going bad, or is something else screwed up like my tierods or something? Thanks in advance.
January 22, 200422 yr sounds like wheel bearings to me cvs usually click and pop when you turn sharp when they are going out check the cv's by checking for up and down movement.. grab the shaft from under the car and pull straight down and then push up (on the middle of the shaft) They shouldnt have play going up and down, just side to side
January 22, 200422 yr Author Ok, thanks for the advice. Is it expensive to replace wheel bearings, and is it necessary? I mean, if I neglect it for a while is there a danger of failure?
January 23, 200422 yr There is the potential of a bearing getting so hot that it seizes and locks the wheel. This is extreme, and usually preceded by a lot of loud grinding/whirring noises, so keep your ears open, and start planning the bearing swap.
January 23, 200422 yr Sounds exactly like my situation 3 weeks ago with my 91 Legacy. Came and went sporadically, in a straight line or when turning, no pattern. It was the outter CV joint!
January 24, 200422 yr Author Originally posted by Setright There is the potential of a bearing getting so hot that it seizes and locks the wheel. This is extreme, and usually preceded by a lot of loud grinding/whirring noises, so keep your ears open, and start planning the bearing swap. The CVs are old anyway. Perhaps I will keep my ears open as suggested and wait until I really need to make the repair. It could wait till this summer. Thanks guys, and take care. Regards,
January 24, 200422 yr I'd suggest, jack up the car and see if there is free play on the front wheels. The nut on the end of the drive shaft may be lose or even the lower ball joint may be worn.
January 24, 200422 yr dangers or bad wheel bearing? you axle could seize up. Add 55 mph to that and you got a flip into the ditch.. jack the car up and pull on the tires. You can usually feel it by doing that if the bearings are going. Wheels bearings arent too expsensive and arent too hard to replace. Not sure on the newer soobs if they have to be pressed out like the ones on my 86
January 27, 200422 yr Author Originally posted by torxxx dangers or bad wheel bearing? you axle could seize up. Add 55 mph to that and you got a flip into the ditch.. jack the car up and pull on the tires. You can usually feel it by doing that if the bearings are going. Wheels bearings arent too expsensive and arent too hard to replace. Not sure on the newer soobs if they have to be pressed out like the ones on my 86 I will have the front end inspected soon anyway. Thanks!
