June 7, 200916 yr for a 97 subaru legacy 2.5.. is a mt starter the same a auto starter?? would they interchange???
June 7, 200916 yr I don't believe so. INfact a 97 AUto is a bit of a weirdo. If you compare it to a 95,96,98,99 (IIR) it's a little longer where it extends into the bell housing.
June 7, 200916 yr If you don't want to spend any $$ and already have one of each then you can take both of them apart and reassemble to get a good one in the configuration you need. Did that to one of mine about 3 months ago, took like 10 minutes.
