EA 82 rear caliper question
When replacing the rear pads, does the piston thread in like the fronr, or compress straight in?
THNX
presses in. i actually did one today and pressed it in by hand, don't even need a c-clamp.
the threaded fronts are only due to the parking brake mechanism.
Good news, thank you for the fast reply:)
Im doing the rear wheel bearings and also double shocking the rear with gabriel hijackers airshocks, (sick of the rear sag,bottoming out)....
Going to be alot easier with knowing what I need beforehand.I appreciate it. THNX
Edited by mykingcrab
