Legacy sway bars
Is there a difference in the size of the sway bars between the L LS LSi and GT models? I assume there is but I can't find anything that says exactly what the size difference is if any. The junkyard I go to charges $12 for a sway bar, and it would be so nice to get a little larger one on this thing to cut down on body roll.
Are those actual Subaru part numbers? Because that's my new favorite website if they are. :eek:
They come up with different part numbers. And there's a place under the listing for the stabilizer bar that appears to be which years the part was used and it says Stabilizer D=xx. I'm guessing that's the size in MM. There's a 1mm difference between all the fronts and all of the rears. Not sure how much difference 1mm will make. There might be a complete overhaul of the suspension in the works then.
If I remember right, for 90-99 Legacys:
Front Swaybars are the same for all for the most part.
L, LS, LSI will have 14mm rear bar.
96-99 GT 16mm rear bar.
96-99 Outback 18mm rear bar.
if you click on the part number it will give you a usage page for that part. then click on usage info and it will list the cars and years for that part.
