July 27, 200916 yr MY 96 impreza 2.2 auto has a knock sensor code. Where is it located on the engine ? Bought new one from the dealer...The other thing is when I select Reverse or Drive 3,2 etc the trans hums/whines, which changes with the rpm changes...just like the older cars with bad alt. But no whine when in Park or Neutral , any ideas. I was told the torque convertor is on it's way out.. Who has the best reference books on these cars... Because it sounds like I am going to need lots of help.... Thanks in advance
July 27, 200916 yr Look at the lower left of this screen right now, scroll to the bottom. You'll see no less than %100 matching threads in all 5 cases of "similar threads"!:banana: Familiarize yourself with the search function as there's a great thread detailing everything about this - why they fail, your options for replacement, pictures, and exactly how to do it.
July 27, 200916 yr Author AWESOME.... I read what you suggested and I found it..... took less than 10 min to remove/ replace including getting and putting tools back in box...+ dielectric grease... And just for fun installed new Red Bosch plug wires.... INCREDIABLE ............... THANKS...
