August 10, 200916 yr My car was showing some hesistance in the past week. Now it will turn over and I have spark to all cylinders. Fuel pump pressure is 24psi with clean filters,but it won"t start. I have very little hair ,but I'm ready to tear it out. Can anyone suggest what to check next? Regards
August 10, 200916 yr I guess I'd check for compression in all cylinders. Ideally,you would have 150 lbs/psi or so,in each hole. If you have good compression,then I'd be looking at a possible plugged exhaust. Like maybe the cat is plugged. Edited August 10, 200916 yr by markjw
August 10, 200916 yr If you have fuel and good spark, just about has to be a timing problem. How old are the timing belts? Old belts have been known to loose teeth before breaking.
