August 18, 200916 yr I am in the process of looking for a winter beater. I came across a 2000 Outback. Here is some info. What is the most likely cause of this symptom? Is it common? How is it fixed? 2.5 dohc check engine lamp is on because of a transmission code.....(gear ratio error in 3rd) runs great. this would make a great donor vehicle or fix trans and have a great car! has all the options...leather , heated seats , pw etc. $995
August 18, 200916 yr wow, that's a great deal! I just bought my '00 OBW for 4K + taxes. sorry, I dont know about the trans code.
August 18, 200916 yr Author P0733 is the code I was just told. Has 190k on the clock. I did not see the car yet or drive it. Edited August 18, 200916 yr by pwned
August 19, 200916 yr something you need to look into, the 2000 Outback isnt a DOHC its SOHC. so the year is most likely a 1999 with the DOHC engine.
