do I need to make a radiator cleanup?
hey :)
my AC is working fine , all the mechanic's that I go to , told me that,
I put another electric fan on the condenser, to improve the gas cooling
(I use R12 ) it does not help to much, there isn't any leaking gas
the car does not overheat at all , do I need to make a cleanup to the water radiator ? it will help?
the car is 87 GL sub EA82 hitachi carb, 4wd manual.
so you have no cold air coming from the AC? Did the mechanics put a set of gauges on the AC system? No mechanic is just going to give back a customers car with weak ac and say it is fine without further investigation.
AC is one of the simpler things to diagnose, as there isnt much to go wrong. STick a refrgerator thermometer on the air outlet, and tell us how cold the air is and how warm the outside air is.
Does your air move from floor to dash to defroster with the buttons?
nipper
