August 31, 200916 yr I am getting ready to drill out my hubs to Toyota six lugs. I am going to be running a 15 inch wheel. What is the absolute biggest tire i can run. I was hoping to get around the 27 inch range. I do not mind cutting at all, i have a sawzall,l cutting torch, and plasma cutter. Thanks, Wes
August 31, 200916 yr hey , i just put 205 / 55 / 15 " on a 81 gl wagon , i need to trim the front wheel wells just a little to turn sharpe . looks feally cool , hope to get some pic's on here soon
August 31, 200916 yr I am getting ready to drill out my hubs to Toyota six lugs.I am going to be running a 15 inch wheel. What is the absolute biggest tire i can run. I was hoping to get around the 27 inch range. I do not mind cutting at all, i have a sawzall,l cutting torch, and plasma cutter. Thanks, Wes You can get 30's on it if you really want to cut out the fenders....... just do a 2" lift and you can fit 27's, (205/75/15-215/75/15)with very little trouble.................. Jeff
