EA82 Cylinder Block Coolant Passage O Ring
3 replies to this topic
#1 hackasubaru
hackasubaru
    USMB Regular
  • PipPipPip
  • 53 posts
  • Portland
Posted 22 July 2010 - 02:04 PM
I recently did head gaskets on my 87 gl wagon because i was getting oil in the coolant. I bought a regasket kit for the top and bottom end and have been replacing lots of things. Although, i noticed in my hanes there is a "crankshaft o ring" and "backup ring" right where the block splits. I read a service manual online and it called it a coolant passage o ring. I was wondering if anyone knew if these go out very often and if they do can it cause oil in the coolant? I really don't want to redo my head gaskets :(
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,699 posts
  • Portland
Posted 22 July 2010 - 03:36 PM
They don't fail - don't worry about it.
#3 hackasubaru
hackasubaru
    USMB Regular
  • PipPipPip
  • 53 posts
  • Portland
Posted 22 July 2010 - 05:05 PM
Hey cool, thanks for the quick response! I figured something so hard to get too would be fairly reliable. I won't worry about it, time to put my engine back in
-Jake
Edited by hackasubaru, 22 July 2010 - 05:12 PM.
#4 Gloyale
Gloyale
    It's a sickness
  • 10,642 posts
  • Corvallis, OR PNW
Posted 23 July 2010 - 11:47 AM
I could see it leaking coolant into the oil, but not the other way around.
There is no oil at the top of the block.:rolleyes:
And they don't fail really. If it did, you'd have to remove the heads and redo the headgaskets to split the case to get at it anyhow.
