Best Clutch for 92 Loyale With EJ 2.5L?????
4 replies to this topic
#1 SubiePimp
SubiePimp
    New User
  • PipPip
  • 22 posts
  • Bellingham
Posted 30 January 2011 - 07:57 AM
I HAVE A 92 LOYALE PUSH BUTTON 4WD. I ORDERED THE EA TO EJ ADAPTER KIT FROM SJR LIFT. BUT NOW IM HAVING TROUBLE FINDING A NON OEM REPLACEMENT CLUTCH FOR MY SWAP. JUST CURIOUS IF ANYBODY HAD ANY SUGGESTIONS ON SOMETHING THAT WILL HOLD UP OR EXAMPLES OF CLUTCHES THEY MIGHT HAVE USED IN A LOYALE SWAP IN THE PAST. ANY HELP IS APPRECIATED. THANX
i have also heard that the xt6 is the best clutch you can get fro the S/R pb 4WD.NOT SURE IF ITS TRUE THO.http://www.ultimates...es/banghead.gif
THANX
Eric.http://www.ultimates.../dead_horse.gif
#2 cmiller
cmiller
    Flat 4
  • 735 posts
  • Tigard, OR
Posted 30 January 2011 - 12:40 PM
I replied to the message you sent me. Also take a look at this thread I did a while back on my EJ swap for my Loyale. All of the info you could need is in there with pics. http://www.ultimates...ad.php?t=103355
#3 cmiller
cmiller
    Flat 4
  • 735 posts
  • Tigard, OR
Posted 31 January 2011 - 10:19 AM
Any year XT6 clutch kit is fine. What you really need out of it is the greater clamping force with the pressure plate. The clutch disc is the same as any other EA82 I believe.
#4 987687
987687
    Rally Suby!
  • 4,239 posts
  • Northern Maine
Posted 31 January 2011 - 03:40 PM
I think your capslock key is stick...
#5 Gloyale
Gloyale
    It's a sickness
  • 10,563 posts
  • Corvallis, OR PNW
Posted 07 February 2011 - 06:39 PM
BEST option if you are keeping the S/R Loyale trans, would be to stuff the shafts and tailsection into an EJ trans case (EASY) . Then you can bolt the engine and trans directly toghether, no adapter plate. Then you are free to use an EJ flywheel and clutch.
I recently did this in my S/R GL w/ EJ22 (ditched the EA clutch and adapter plate) The clutch action is much better.
But that said, an XT6 or even just a good 4WD EA82 clutch will work fine.
