messed up tranny oil change
3 replies to this topic
#1 alxborg
alxborg
    New User
  • Pip
  • 4 posts
  • NC
Posted 04 March 2004 - 07:40 PM
I drove up my ramps to innocently to change my fliud as descibed to me by a pro however I must have not heard him correctly,,,so...I drained to fluid and what I thought it needed(nearly a gallon all at once-and before I knew- fluid everywhere!! NOW IT IS REALLy PISSED AT ME -CAN'T BLAME IT!!!Now it will not move much and is making clicking sounds..like air in valves???Any help would be greatly appreciated. I siphoned it down to nearly the stick level and still no luck. Have mercy on me-I do know better!
#2 speedbump
speedbump
    USMB is life!
  • 179 posts
  • North Vancouver,Canada
Posted 04 March 2004 - 08:44 PM
did you start the car and then....shift to reverse and hold for 30 sec,shift to drive and hold for 30 sec,shift to second....
this purges air out of the system.check yourfluid level after running through all the gears
cheers
#3 TROGDOR!
TROGDOR!
    Pastor of Muppets
  • 2,106 posts
  • Morgantown, WV
Posted 04 March 2004 - 09:04 PM
Did you even drain the fluid? There is a plug on the bottom front of the transmission pan; drain it until it's empty, then put the PROPER amount of fluid in, and try it again.
If I remember right the max capacity is about a gallon. Start with 2 quarts and work your way up. Be sure to check the fluid with the engine running.
#4 88rxsedan
88rxsedan
    Subaru Fanatic!
  • 385 posts
  • san antionio
Posted 05 March 2004 - 02:27 AM
did you accidently drain the engine oil or the diff oil?
