soobie_newbie67 Posted September 27, 2012 Share Posted September 27, 2012 The hydraulic tensioner is being stupid. It pushed out and now I can't get the timing belt back on. Help please. Quote Link to comment Share on other sites More sharing options...
cal_look_zero Posted September 28, 2012 Share Posted September 28, 2012 Gotta unbolt it and compress it in a vice or c clamp. Put an allen key or something to hold it in place, install everything, and pull the key to release the tension. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 28, 2012 Share Posted September 28, 2012 That's it's job. That's how it works. It needs to be SLOWLY compressed in a vice or large C-clamp. It should take somewhere in the range of 3 - 5 minutes. Use a small nail or Allen driver stuck through the holes in the tensioner housing and plunger to hold it back while you install it. Quote Link to comment Share on other sites More sharing options...
TOONGA Posted September 28, 2012 Share Posted September 28, 2012 which type do you have? this or this taken from here with either tensioner you must slowly push the piston back into the sleeve. if you push it in too quickly you may damage the internals, causing the tensioner to fail. you will see, once the tensioner piston is all the way in. where the pin or allen key goes. (make sure you put the key in so it faces out) hope this helps TOONGA Quote Link to comment Share on other sites More sharing options...
davebugs Posted September 28, 2012 Share Posted September 28, 2012 The old style (brass ones) were sturdy, reliable, and easily reusable. The newer style seem less sturdy and expensive. But I'd usually replace them. IIR you have to pay close attention to their orientation when compressing hem too. I take a long time to compress either of those. If you wer ein the US I have a few "kits" including the aluminum piece that goes onto the block to allow use of the old style tensioner, an old style tensioner, bolts, etc. Quote Link to comment Share on other sites More sharing options...
soobie_newbie67 Posted September 28, 2012 Author Share Posted September 28, 2012 Got it. Successful timing belt installation. And I have the second style tensioner Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 14, 2012 Share Posted October 14, 2012 Glad it's working, yes the second style (older style) is more durable and slightly more forgiving. The key is sllooowwww compression, especially on the newer style. Else it pukes out the silicone fluid and then you have to replace. Though replacement on the newer style ones isn't a bad idea anyway. Quote Link to comment Share on other sites More sharing options...
