86 gl ecs
3 replies to this topic
#1 gilty
gilty
    New User
  • Pip
  • 4 posts
  • oregon
Posted 16 November 2012 - 01:22 PM
Hello, I have a 1986 gl 5sp fwd stock carb ea82. It will start and run at a high idle for 20 sec or so then die. The ECS light comes on. If I spray some starter fluid I can keep the car running.The carb was rebuilt recently. The fuel pump seems to work fine.Where should I start to fix this?
#2 Indrid cold
Indrid cold
    Subaru Nut
  • 788 posts
  • Kennewick, WA
Posted 17 November 2012 - 02:41 AM
Welcome to the site.... Gilty,
As a reference, here is what is said right out of the Chiltons. "Engine starts but stops immediately: 1. Loose or faulty electrical connections at distributor, coil or alternator. 2. Insufficient fuel reaching the carb. Disonnect the fuel line at the carb. Place a container under the disconnected fuel line. Observe the flow of fuel from the line. 3. Vacuum leak at the gasket surfaces of the intake manifold and or carburetor. Assure all mountin bolts and vacuum hoses are connected to the carb. and 4. Faulty ignition ballast resistor. (chpt 5) *what ever the heck that is...??
If I remember right... there are two filters, one by the fuel pump and one in the engine comp. (fuel seperator) that can plug. After it dies check for spark.. bright blue.. jumpy spark other wise potential weak coil or Ignition module in distributor, or items above from the Chiltons. . Agreed, what you are describing sounds like fuel starvation. But just trying to confirm to eliminate the "what it is obviously not" as these cars get older they just seem to do what they want and usually more than just one item is causing a problem. sometimes...
It does sound fuelish.. Possible plugged fuel filters??? Some carbs have little pressure regulators by them (but may be confusing models/years) possibly failure there.... Just tossing out things here... Being careful with the raw gas but you could disconnect the fuel supply and add line to run to a container and turn ignition on and see fuel delivery when trying to start. Spray Carb cleaner into some of the little ports in carb?
Yes, ECS light on the "Electronic Control Module", "ECM", will flash a red light "code". You have to connect the "test connectors", read codes then disconnect. Do a search on the task bar above in "search".
I am not a mechanic... just pretend to be one on the weekends. I am not that familiar with the year you have. Possibly others can get your further.
Fuel and Spark and just tossing out ideas. My .o2
Edited by Indrid cold, 17 November 2012 - 11:16 AM.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 22,049 posts
  • Portland
Posted 17 November 2012 - 11:17 AM
You fix that problem with a Weber DGV.
You can pull the codes, etc but you'll likely find that an assortment of sensors are bad and one in particular - the MAP sensor - always fails. This one sensor is more expensive than a new Weber carb and you can't find good used ones because they have all failed and there weren't many out there to start with. The whole computer controlled carb system is aweful to work with and extremely outdated. Just get a Weber and toss all that junk in the dumpster.
#4 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 17 November 2012 - 11:21 AM
start with the neddle and seat for float on the neddle seat is a small screen that likes to plug up and bypass feul around the carb make sure your feul pump timer is working haveing a ecs light whould indacate a ecc carb that has a metering jet is it stuck in one position or failed ?
