crank pully question
5 replies to this topic
#1 86subaru
86subaru
    Elite Master of the Subaru
  • 3,052 posts
  • ohio
Posted 27 November 2012 - 03:42 PM
ok found a key way [ half moon] is it possible to put key in with out removing radiator 95 impreza a/t 2.2 ?
#2 cal_look_zero
cal_look_zero
    Subaru Nut
  • 557 posts
  • Grass Pants, OR
Posted 27 November 2012 - 03:56 PM
Just pull the fans. 95 should be 2 bolts on top for each one, and the connector at the bottom.
#3 grossgary
grossgary
  • Gold Subscribers
  • 18,055 posts
  • West VA
yes
#4 86subaru
86subaru
  • 3,052 posts
  • ohio
Posted 27 November 2012 - 03:58 PM
removing the fans will give me enough room to put in the keyway [ half moon] ?
#5 davebugs
davebugs
    I don't "friend"
  • 3,078 posts
  • Pittsburgh suburbs (NE)
Posted 27 November 2012 - 04:09 PM
You'll have room to install it.
IMO NOT enough room to fix the actual crankshaft. I pull the engine to fix the keyway.
#6 86subaru
86subaru
  • 3,052 posts
  • ohio
Posted 27 November 2012 - 08:04 PM
got it ,, after alittle tapping , thanks
