Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
white smoke
#1
Posted 13 December 2012 - 06:53 PM
#2
Posted 13 December 2012 - 07:10 PM
have you re-torqued the heads yet?
#3
Posted 13 December 2012 - 07:14 PM
Edited by mikaleda, 13 December 2012 - 07:21 PM.
#4
Posted 13 December 2012 - 07:42 PM
#5
Posted 13 December 2012 - 07:56 PM
thanks for the replys, the smoke (steam) is coolant, it leaves water on the driveway below the tailpipe. everything (pistons, valves, heads) looked pretty good, maybe just the usual cracks from valve seat to sparkplug threads. i have only run it about 30 minutes, do i need to retorqe subaru head gaskets? i will crimp the coolant line and see if the smoke quits. how long can i crimp the line and not fry the turbo? thanks again, red
Cracks? Did you have the heads crack checked? That could be the whole issue you may need new heads, but if it is blowing smoke you should have been able to see them.
Edited by mikaleda, 13 December 2012 - 07:59 PM.
#6
Posted 14 December 2012 - 12:50 AM
Lost a turbo XT to this very thing.
You should be able to drop the exhaust and see, but it depends on how bad its leaking. Mine did it for quite a while before I had any real issues from it. it still ran and I traded it off to someone who put stop leak in it and ran it for a while themselves (not recommended).
something to at least look into.
#7
Posted 14 December 2012 - 02:41 AM
#8
Posted 14 December 2012 - 09:07 AM
#9
Posted 14 December 2012 - 03:53 PM
#10
Posted 14 December 2012 - 07:27 PM
#11
Posted 15 December 2012 - 12:18 AM
If a plug check does show a slight white residue on one of the four plugs, then you would have a crack between the intake and exhaust valves there, that also leaks coolant. They fixed this with the mpfi turbo heads but not with the spfi heads, with their GEN 3's.
#12
Posted 15 December 2012 - 02:26 PM
#13
Posted 15 December 2012 - 02:49 PM
The fin between the two exhaust channels that meet at the exhaust outlet, develops a tiny cross crack at one end of the fin. It apparently cannot be repaired.
You are spot on. The turbo heads crack in this area VERY commonly. They can be repaired, but they ussually crack again later. I had a set welded up, put them on an engine and ran it about 20K miles before a rod bearing gave out. when I pulled the heads, only one was cracked!!
The "fixed" Gen 3 heads exist. But they aren't really fixed. Slightly less prone to both types of cracks, but definately still not "fixed"
I'd say about 80%+ of the SPFI heads of any gen, and 100% of the Turbo heads have the Between the valves cracks......mostly not an issue though.
The turbo heads however, even "Gen 3" ones, see about a 90% cracked rate in the exhaust web. Most all of these leak some coolant. Athough I've seen many good running cars, that just barely seep, and have run a long time just topping off coolant.
I don't think it's very good for the turbocharger though:(
hopefully the OP of this thread just had residual water and oil in the exhaust pipe still.
#14
Posted 16 December 2012 - 09:57 PM
OK, i started the car again today, no white smoke at first but it started again as the engine came up to temp, maybe not as bad. pulled out of the driveway and started up the road, i really had a "cloud" going on behind the car. I decided it would either go or blow, so I said a prayer, and let 'er rip. I really had smoke and some funky smells going on. In about half a mile it got a little better, another half mile down the road it cleared up completely. It could have been coolant left in the exhaust. I always get a lot of help from above, and i need it. thanks for the earthly help too, red
That's exactly what I did, and it worked. For a while, it still comes back now and then. Sometimes really bad.
#15
Posted 17 December 2012 - 01:05 PM
#16
Posted 11 March 2013 - 03:25 PM
Redhill,
Any updates? Also, I have a question. Does the engine run like it has a miss, or at least a partial miss, when it's smoking?
#17
Posted 11 March 2013 - 03:36 PM
I'm going to assume you have a standard...but a leaking vacuum modulator on the Auto Trans can cause this...Granted mine only did it when i would turn, it sounds like your does it quite a lot more
#18
Posted 13 March 2013 - 01:31 AM
Hi,
'the smoke (steam) is coolant,' are you positive that the smoke is coolant/steam because every exhaust will have some condensate - how much water are you losing in (say) a ten mile journey? Have you also ruled out worn valve-stem oil seals?
