Distributor Question
6 replies to this topic
#1 TallonX
TallonX
    USMB is life!
  • 175 posts
  • Rochester, Wa
Posted 24 March 2013 - 05:28 PM
Don't know if I'm posting in the right spot or not but...
I'm the proud owner of an 88 GL wagon EA82 2bbl 240k on the odo and I'm trying to figure my options regarding my distributor. Typical signs ie: play, intermittent tach twitch, and missfire on acceleration from stop to turning
When I look one up online from schmucks and it shows me the 4-pin fool infected dizzy, mine is not the optic system.
Question being, can I swap to the optic dizzy? I used one of them kits once on a 73 Ford and same year Chev to upgrade the ignition system. Same principal isn't it?
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 24 March 2013 - 05:59 PM
backlash in the timing belt can cause a jumpy tqch. something to consider since the disty is driven by the cam.
#3 TallonX
TallonX
    USMB is life!
  • 175 posts
  • Rochester, Wa
Posted 24 March 2013 - 06:06 PM
No miss fire when the tach jumps...
Example: Rollin at 60mph 3000 rpm fifth tach twitches up by 500 or so drops back to 2750 rpm or so no stumble or hesitation loss of power or noises
#4 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 24 March 2013 - 07:02 PM
you have an 88 with a carb? is the engine swapped, as it should have been spfi for the year. maybe it's a late 87?
either way, if it's carbbed, look for 85-86 year listings for '1.8 ohc' listings
#5 Gloyale
Gloyale
    It's a sickness
  • 10,644 posts
  • Corvallis, OR PNW
Posted 25 March 2013 - 11:39 AM
Do you have the denso, or hitachi distributor(denso=brown cap, hitachi, black)
I also think it could be something else. If the tach twitches but the engine doesn't miss or seem affected the its probably not the disty. More likely a dash issue.
Anyhow hitachi = 85,86
Denso = 87
All 88 are FI withy the 4 pin optical. No you can't use that disty.
Edited by Gloyale, 25 March 2013 - 11:41 AM.
#6 TallonX
TallonX
    USMB is life!
  • 175 posts
  • Rochester, Wa
Posted 25 March 2013 - 11:56 AM
It's a nippy... all original kinda rig. I'm no stranger to oddball rigs they seem to find me lol
Any difference when it comes to Mexican models?
#7 rdweninger
rdweninger
    USMB Regular Nut
  • 772 posts
  • Tillamook, OR
Posted 25 March 2013 - 06:27 PM
Mexican models usually have long black hair.
