used car Posted April 19, 2013 Share Posted April 19, 2013 I have 1987 subaru gl 1.8 liter sedan.Choke no longer works on cold mornings.I have to use accelerator to rev it up until engine warms up.Whats wrong and how to fix it? Thanks Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted April 19, 2013 Share Posted April 19, 2013 is this a carburetor or spfi ?? 1 Quote Link to comment Share on other sites More sharing options...
mikaleda Posted April 19, 2013 Share Posted April 19, 2013 If its carbureted, the auto choke needs to be adjusted. If its Spfi code check would be first step, coolant temp sensor also can cause these kinds of problems too. Quote Link to comment Share on other sites More sharing options...
used car Posted August 4, 2013 Author Share Posted August 4, 2013 Yes it is 2 bl carburator.How can the choke be adjusted to make it work? Quote Link to comment Share on other sites More sharing options...
TomRhere Posted August 4, 2013 Share Posted August 4, 2013 Chances are the end has broke off of the bi-metallic spring. That is the most likely cause of choke not setting. You have to drill the rivets out that hold the cover on to replace the spring. Use self-tapping #8-32 screws to put the cover back on. Quote Link to comment Share on other sites More sharing options...
mikaleda Posted August 6, 2013 Share Posted August 6, 2013 (edited) Or covert to Manuel choke, simpler and way less hassle afterwards. Also to adjust, loosen the three retaing screws and turn until you see the choke plate close almost all the way. Make sure once it warms up that its opening all the way as well, it may take some tinkering to get it right Edited August 6, 2013 by mikaleda Quote Link to comment Share on other sites More sharing options...
