90' DL just died
4 replies to this topic
#1 Lou Baroo
Lou Baroo
    Member
  • PipPip
  • 10 posts
  • PNW
Posted 17 September 2013 - 01:36 AM
Here is what I know:
Bought a 90' DL wagon (non turbo) drove around for a few weeks mostly no problems. In for brakes, stops VERY nice now.
Sold / Gave to daughter who left Seattle area no problem. Around Woodburn Oregon, she reports the following:
"CEL" flashed on, engine died. She tried starting, it will crank. Simply will not fire.
Of course we will have timing belts checked - I don't recall if CEL comes on when one fails.
Any other suggestions?
As a side note I must say I am TOTALLY impressed with this forum. I've been reading for last 3 weeks since I picked up this ride. I did have an 87' DL (2WD) for 15 years / 200K miles and did most of my own work. I could do timing belts in under 30 minutes by the time I got rid of it :-)
#2 AKghandi
AKghandi
    87 GL-10
  • 1,201 posts
  • Somewhere, Someplace
Posted 17 September 2013 - 04:05 AM
hmmmm....best way to tell is to check the code. it could be any number of things.
http://www.ultimates...-for-1983-1988/
I know it says 83-88 but it should be mostly the same for a 90... also, i didn't know they made DL in 90. i thought in 90 they went to loyale.
#3 Mark Humble
Mark Humble
    USMB Regular
  • PipPipPip
  • 121 posts
  • Lewiston Ca.
Posted 17 September 2013 - 09:44 AM
Yes, the CEL will come on if the drivers side timing belt breaks.
Mark
#4 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 17 September 2013 - 12:56 PM
First check to see if the set screw had fallen out of the rotor under the cap. If it is there , great. Verify the distributor is turning while cranking. If not, bet on a broken timing belt.
#5 Lou Baroo
Lou Baroo
    Member
  • PipPip
  • 10 posts
  • PNW
Posted 20 September 2013 - 08:40 AM
Yup, it was a driver's side timing belt.
Won't even go into detail on the bs with the mechanic it was taken to, but I will say if you and your Subaru are stuck in Cottage Grove Oregon, I would not be going to B&A Auto.  Not only are they bozo's, they will likely tell you your car is an old POS.
No kidding.
The good news is we found a fellow down there who knows the boxers inside out, and will be taking good care of us.
Thank you again to everyone here.
