96 legoback 4eat dirt clod noise turned to TERRIBLE TRANSMISSION GRIND!
4 replies to this topic
#1 bluedotsnow
bluedotsnow
    USMB is life!
  • 341 posts
  • Kirkwood, CA
Posted 18 September 2013 - 04:15 AM
so I had lots of fun in our dirt field and got enough dirt clods stuck in my heat shield to cause high pitched whining and grinding noise. after getting it home and putting it on jack stands we found the problem. I cleared the clods and started it back up everything was cool until a friend put it in park without hitting the brakes.... so after shutting it off and restarting applying a small amount of throttle causes A TERRIBLE JOLTING/GRINDING/POPPING of the transmission seems to be coming from the 4eat tail housing. hoping its a easily fixable pawl issue, who knows will post picks tomorrow...
I'm relatively familiar with the parking pawl and the drive driving hubs so if there is catastrophic failure of hard parts this might turn into a "thats why you don't do that ever" topic
#2 lmdew
lmdew
    _______
  • 3,763 posts
  • Colorado Springs
Posted 18 September 2013 - 06:25 AM
Pretty easy to drop the tail shaft housing.  Yep you will need to get in there to see what damage is done.
Search torque bind and you will find some good picture.
#3 bluedotsnow
bluedotsnow
    USMB is life!
  • 341 posts
  • Kirkwood, CA
Posted 18 September 2013 - 12:54 PM
rofl no its not torque bind as if it were in the general sense,  duty c solenoid and clutch packs were replaced not to long ago if you want a good laugh and a long read then search for a "no awd" thread I posted way back when I paid a shop to fix that stuff and they made it way worse. fixed it myself after they mucked it, applied knowledge PRICELESS!!!
#4 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Posted 18 September 2013 - 05:17 PM
He is not suggesting it is torque bind at all. He's saying you will find the pictures you are looking for by searching torque bind.
#5 bluedotsnow
bluedotsnow
    USMB is life!
  • 341 posts
  • Kirkwood, CA
Posted 20 September 2013 - 05:40 PM
oh lol I gotcha as if I had never done that service before, plenty of experiance with tail section ( shakes head while holding it with hand)
sooooo parking prawl poped out at me reinstalled after inspecting hard parts everything was fine, got a little freaked out when the at temp light started flashing at me but after shifting through gears and a few starts no more flashing and no tcu codes. I took the extra day to get the factory gasket, having a major atf pathway an inch from the lip of the case no way in hell I'm going to trust just rtv or gasket maker!
