briankk Posted October 8, 2013 Share Posted October 8, 2013 So, I'm going down the road pretty much flat out in 4th or 5th, engine WFO under full load at 3500 to 4k, when suddenly the engine goes flat and a huge oil cloud bursts fourth from the exhaust. "Oh spoob", I'm thinking, "holed a piston, or sucked a valve" In just that amount of time, it quits smoking and the engine regains power, and I'm off. This happens once about every 2 months, sucks a big glop of oil, spits it out, keeps on going. WTF? Anybody ever heard of this? How can the engine suddenly suck in a bunch of oil all in a lump, then not do it again for a couple of months? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 8, 2013 Share Posted October 8, 2013 Usually it is due to a Problem with the Positive Crankcase Ventilation Setup & PCV Valve. More info on your Engine model, if it is EFi or Carb will Help to give the Proper answer. But if it is Carb'd, then it could be a Stuck Open PCV Valve, if it is EFi, there is a Factory Re-route Kit for the PCV setup, That prevents such Symptom. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 8, 2013 Share Posted October 8, 2013 I had similar problems in my "BumbleBeast" and I had to install an Oil Catch Can between the Drivers' side Head Hose and the PCV Valve; follow this Link for more info: ~► http://www.ultimatesubaru.org/forum/topic/114260-oil-catch-can-in-ea82/page-2 There are Photos and Details of the PCV Re-Routing on EFi Models as well. Kind Regards. Quote Link to comment Share on other sites More sharing options...
l75eya Posted October 8, 2013 Share Posted October 8, 2013 I know this isn't helpful advice.. But that actually sounds pretty awesome. 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 8, 2013 Share Posted October 8, 2013 The Cloud of Smoke? Well, thinking about that, sounds like something done by one of James Bond's cars in a Pursuit... Kind Regards. Quote Link to comment Share on other sites More sharing options...
briankk Posted October 8, 2013 Author Share Posted October 8, 2013 Ya know, that all makes sence. Going for that EFI kit, and thanks for your latest help.. brian 1 Quote Link to comment Share on other sites More sharing options...
