1989 gl sw dual range grinds going into gears,clutch is good .Did I adjust the cable wrong?
help
8 replies to this topic
#1 junkmanjason
junkmanjason
    Member
  • PipPip
  • 27 posts
  • MAPLE RIDGE BC CANADA
Posted 30 October 2013 - 05:30 AM
Please I need help!
#2 junkmanjason
junkmanjason
    Member
  • PipPip
  • 27 posts
Posted 30 October 2013 - 05:56 AM
It just barely grinds into second some times 3rd .I just don't want to hurt the tranny. Was front wheel drive auto,now dual range 4x4  posi .New seals, belts almost every weird thing done even new metal in the wheel wells . I have 15 inch pug rims .Rear is already lifted . Would a 2 inch front lift work without losing axles all the time ? could I get away with 3 inch ? I just love this car !
#3 Gloyale
Gloyale
    It's a sickness
  • 10,655 posts
  • Corvallis, OR PNW
Posted 30 October 2013 - 11:55 AM
cable may be too loose.
#4 junkmanjason
junkmanjason
    Member
  • PipPip
  • 27 posts
Posted 30 October 2013 - 10:45 PM
I'll give it another shot ,thanks!
#5 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 31 October 2013 - 09:51 AM
The hill holder cable may need to be adjusted to allow for the clutch cable adjustment. The hill holder cable serves as a clutch return spring when functioning properly
#6 junkmanjason
junkmanjason
    Member
  • PipPip
  • 27 posts
Posted 03 November 2013 - 01:22 AM
I never put the hill holder stuff in my Subaru  when I did the build. Thanks for the assistance,that's really cool.
#7 mr sarcastic
mr sarcastic
    New User
  • 125 posts
  • 03839
Posted 03 November 2013 - 06:34 AM
Can the clutch cable be adjusted correctly without the hill holder mechanism? I also never put the holder in when I did the trans swap... I can't seem to adjust the cable to bring the friction point low on the clutch, it engages super high.
#8 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 03 November 2013 - 06:46 AM
The clutch spring from a FWD can be used on a 4WD clutch fork when the Hill-Holder has been removed.
I'm using a throttle return spring off some other vehicle on my '88 Wagon. All that's needed is a spring of proper length, and not a lot of tension when stretched. All the spring is supposed to do is pull the throw-out bearing away from the pressure plate when the clutch is engaged.
#9 mr sarcastic
mr sarcastic
    New User
  • 125 posts
  • 03839
Posted 03 November 2013 - 06:53 AM
Gotcha. I have been hearing the throwout bearing rubbing against the pressure plate when my foot is off the clutch. I'll rig up a spring to pull it back....
Also tagged with one or more of these keywords: help
