1998 Legacy Outback - 4EAT transmission engagement issues
6 replies to this topic
#1 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,034 posts
  • Grand Valley, PA
Posted 05 December 2013 - 12:16 AM
A friend of ours recently asked for help/advice on her outback. (98, EJ25 DOHC and 4EAT with about 95k)  As explained to me, the transmission wont shift into gear on it's own when it's cold. If she revs the engine a little bit, turns it off, then on again, revs a bit more, it will go into gear.
First order of business was the Trans-X fix. I drained 4.5 quarts of ATF out of the trans, Color was normal, smell was good. filled it back up with new ATF and a bottle of Trans-X. A few days later now, and it doesn't seem any better.
I'm not very experienced with automatics. Replaced a couple, but the functions of them are voodoo to me. What could be the cause of this? And then of course, what's the likely fix?
#2 CNY_Dave
CNY_Dave
    03 LL Bean H6
  • 1,906 posts
  • Near Cortland NY
Posted 05 December 2013 - 09:33 AM
That could be the much discussed 'delayed forward engagement', give that phrase a search on the usual sube sites.
#3 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,034 posts
  • Grand Valley, PA
Posted 06 December 2013 - 03:34 PM
That's what I figured, but if it were that sort of issue, the trans X should make a difference right? I used trans x with great success on the old trnsmission in our 2000 Outback.
Or was there a difference between phase one and phase 2 transmissions that would require a different fix?
#4 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 06 December 2013 - 09:51 PM
it is a different problem.
the 00 trans is a bad seal, i think.
trans-x corrects it for a time.
the 98 problem is obviously different.
time to look for a replacement trans.
www.car-part.com
#5 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,034 posts
  • Grand Valley, PA
Posted 06 December 2013 - 11:26 PM
Safe then to say this tranny is on it's way out? Shifts fine. Drives and accelerates as it should. Just doesn't like to go into gear until it's warmed up.
No biggie. Should be some in the pick n pulls.
Is there a chart for 4EATs? 98 Outback should be a 4.44 phase 1 right? Should apply at least to the outbacks with the DOHC. Any others?
#6 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,034 posts
  • Grand Valley, PA
Posted 06 December 2013 - 11:36 PM
And will any Phase 1 4EAT work with matching diff? Or just 95-early 99?
#7 heartless
heartless
    Do YOU Subaru?
  • 3,296 posts
  • North Central Wisconsin
Posted 07 December 2013 - 07:58 AM
i would stick with the 95-99 model years & the appropriate gear ratio.
90-94 are more than likely going to be 4.111 ratio (no outbacks in those years) plus some minor wiring differences.
