dirty_mech Posted July 7, 2014 Share Posted July 7, 2014 (edited) Hey all. 2000 legacy 150k M/T here. It was in a front collision and the camber got screwed up badly, resulting in the destruction of both front tires. So I got new tires and brought them to a wheel shop. They did the alignment and installed the tires for $50 and $30 respectively. However, the mechanic on deck informed me that they couldn't quite get the camber into the right range (probably due to the impact) and he recommended replacing the camber bolts with some aftermarket ones. So today I got 2 on the quick for about $45 OTD at O'Reilly's (brand: Moog) and paid the wheel shop another $40 to install the camber bolts and correct the camber. However, the mechanic on deck told me that the bolts had not quite solved the problem, and that the car should be driven around for a couple days and brought back for further adjustment (at no charge).So here's my question to the forum: Was this the proper course of action or no? What (if anything) could be causing my camber to be difficult to adjust? Edit: To clarify, the first time the alignment was done at the wheel shop, the mechanic told me that the camber was close, but not in parameters. The consensus seemed to be that I should check the tires for uneven wear after a week or so. I did this, and found that the new-tire nubs on both sides were more worn on the inner track of the tread, rather than even (as I assume they should be?). Cheers Edited July 7, 2014 by dirty_mech Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 7, 2014 Share Posted July 7, 2014 The prbelem was not the bolts to begin with. Suspect bent components Quote Link to comment Share on other sites More sharing options...
lmdew Posted July 8, 2014 Share Posted July 8, 2014 Bent Struts and all 4 tires need to match within the 10% allowed by Subaru. Good visual inspection of the struts, lower A Arm and knuckle are in order. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 8, 2014 Share Posted July 8, 2014 he may have been referring to some 'performance' camber bolts as opposed to OEM-style replacements. i have seen bolts sold to increase negative camber for (supposedly) 'motorsports' purposes. H&R, Whiteline, Eibach and others may have something that would help but , usually these parts are made for the WRX or STI models. another option could be camber plates for the strut mount. It should be noted, these items can sometimes lead to tires rubbing. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 8, 2014 Share Posted July 8, 2014 If the stock bolts do not provide enough adjustment, either the strut or lower control arm is bent. Quote Link to comment Share on other sites More sharing options...
