05 Outback Control Arm removal
bushings control arm repair
3 replies to this topic
#1 tdwhite
tdwhite
    Newbie
  • Pip
  • 1 posts
  • Glen Allen, Virginia
Posted 10 August 2014 - 01:45 PM
Im working on replacing the bushings on my 05 Outback. At first I had trouble removing the control arm from the ball joint (tried both removing the bolt from the pinch knuckle then a beating to the control arm and removing the cotter pin and trying the same beating with a hammer) but I had no luck.  Then decided I might beable to finish the job by leaving it in. So I disconnected the control arm from everywhere but the ball joint and was able to remove the old torn busing and the metal ring around it.  Now I am having trouble pushing in the new bushing.  Does anyone have any ideas on getting the ball joint out? Im going to take both arms to a shop to get them pushed in. I need to have this done by thursday I will be driving back to college.
#2 john in KY
john in KY
    1000+ Super USER!
  • 1,470 posts
  • KY
Posted 10 August 2014 - 06:40 PM
Use a pickle fork and buy new ball joints because the pickle fork will damage the original ball joints.
http://www.ehow.com/...all-joints.html
Edited by john in KY, 10 August 2014 - 06:42 PM.
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,055 posts
  • Charlottesburg, VA
Posted 10 August 2014 - 10:48 PM
I use a 3lb hammer and strike the at side of the control arm where the ball joint stud goes through. 3-4 solid hits usually pops it loose.
It also helps to have a large prybar to help pull the control arm down while you swing the hammer.
Since you have the bushings knocked out of the arm you'll have put it back in place and slide the bolts through to hold it.
The steel sleeve bushings can be a pain to replace without a press, but a vice usually works to push the new ones in.
#4 14D
14D
    Advanced Member
  • PipPipPip
  • 42 posts
  • Arizona
Posted 11 August 2014 - 07:52 AM
I've used a 2/3 arm puller on stuck ones before.  Something like this would work even better though.
http://www.harborfre...ator-99849.html
