tytuk Posted January 23, 2015 Share Posted January 23, 2015 , So i had a failed pneumatic suspension system in my 1987 xt gl10. I Swapped it to coil overs, every thing is great except, The height indicatior light (little picture of car) jumps up and down flashing. So my question is can i make this stop? i have pulled the fuse for the compressor. Do i need to unplug the compressor instead, if so how do i access it? thanks... Quote Link to comment Share on other sites More sharing options...
john in KY Posted January 23, 2015 Share Posted January 23, 2015 The control unit is located under the driver side door sill. Really need to pull the seat, roll back the carpet to gain access. Plus you have to remove that plastic sill plate. Anyways, just unplug it and problem solved. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted January 23, 2015 Share Posted January 23, 2015 At each strut you cut a wire. Inside are 4 condutors. Tie together the blue/brown wires, and the system thinks it's at normal height. Easier than pulling apart your interior. Quote Link to comment Share on other sites More sharing options...
AWD J3wman Posted January 23, 2015 Share Posted January 23, 2015 or you can just completely pull the compressor out and sell it to me if it still works? Quote Link to comment Share on other sites More sharing options...
tytuk Posted January 25, 2015 Author Share Posted January 25, 2015 thanks so much guys, i ended up pulling the seat to do it. it was super easy and took less then 10min and everything went back together great… Quote Link to comment Share on other sites More sharing options...
