kirzick Posted April 4, 2015 Share Posted April 4, 2015 Hey all. I did try searching i just didnt find anything. I'm in the middle of swapping in a ej22 into my gl. The harness is from a 92 and the engine is a 90. The engine harness has three grey plugs while my harness has two white / grey plugs. Can I just switch the engine harness? Thanks Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 4, 2015 Share Posted April 4, 2015 Yes you need a 92 intake harness. And if the Intake is from a manual 90 car, you will need a 92-94 iac also. Quote Link to comment Share on other sites More sharing options...
kirzick Posted April 5, 2015 Author Share Posted April 5, 2015 Okay thanks! Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted April 5, 2015 Share Posted April 5, 2015 The third plug is almost all grounds on the early harness if that helps Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 8, 2015 Share Posted April 8, 2015 The third plug is almost all grounds on the early harness if that helpsit's all grounds. But the wires int the other 2 connectors have a completely fDifferent arrangement. 1 wire of 1 of them is in the same spot Get a correct intake harness Quote Link to comment Share on other sites More sharing options...
