ScottAust Posted April 12, 2015 Share Posted April 12, 2015 Hello, under the bonnet of my 1998 outback there is a fuse holder (with no fuse) that has 4WD on it. Silly question- what happens if you put a fuse in it ?? Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted April 12, 2015 Share Posted April 12, 2015 Normal use is no fuse. Install a fuse, car operates in front wheel drive only. Quote Link to comment Share on other sites More sharing options...
ScottAust Posted April 12, 2015 Author Share Posted April 12, 2015 So would putting a fuse in for normal around town on bitumen roads be better for fuel consumption? Would it do any damage ? Quote Link to comment Share on other sites More sharing options...
987687 Posted April 12, 2015 Share Posted April 12, 2015 Since there's no axle disconnects on a subaru, all the rear driveline will still be spinning even if you put the fwd fuse in. So you don't gain anything. It's also argued that giving full duty cycle to the C solenoid is bad and will burn it up, I dunno if it's true or not, but just leave it in awd. Quote Link to comment Share on other sites More sharing options...
ccrinc Posted April 13, 2015 Share Posted April 13, 2015 Won't hurt anything either. Most mpg you might gain would 2-3 anyway. Quote Link to comment Share on other sites More sharing options...
ScottAust Posted April 13, 2015 Author Share Posted April 13, 2015 And here I was thinking someone would say you have a super rare special model and if you put a fuse in it will lock the the diffs and double the power ! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 13, 2015 Share Posted April 13, 2015 4wd or Fwd? Big difference. In some countries (not the US) there was an option to lock into 4 wheel drive, by installing a fuse in the fuse holder labeled "4WD" on the strut tower. Its in about the same place as the "FWD" fuse holder on the US models. Except the Fwd fuse holder does the opposite. It totally disengages the AWD, and gives you only front wheel operation. It would be kinda neat to know which pin on the TCU that fuse goes to. Could be useful for people here who like to run a switch to the duty c solenoid to lock the transfer clutch into 4wd. Quote Link to comment Share on other sites More sharing options...
ScottAust Posted April 13, 2015 Author Share Posted April 13, 2015 I will check tonight but I'm fairly sure it was 4WD. Yes it's just behind the strut tower on the right side. Maybe I should put a fuse in and see what it does ? Quote Link to comment Share on other sites More sharing options...
ScottAust Posted April 13, 2015 Author Share Posted April 13, 2015 No I was wrong it's says FWD ! Thanks for the help Quote Link to comment Share on other sites More sharing options...
ccrinc Posted April 13, 2015 Share Posted April 13, 2015 Rick has put a toggle switch on the dash of 2 of my now long gone Subarus so that I could flip between AWD and FWD as I wished. I ran my '92 Legacy Turbo Touring Wagon LE in FWD most of the time and only flipped into AWD when the conditions required it. I had that car the longest, so it was like that for several years and still no transmission troubles when I finally sold it. 1 Quote Link to comment Share on other sites More sharing options...
