Since Engine Swap Trans not shifting properly
Did you fill the torque converter BEFORE bolting it up? Any time you pull an auto trans, you should drain the old fluid from the pan AND the converter. Fill the actual converter back up so it's at least at spline level (pour in through spline opening). Then add a ballpark amount of fluid to the trans (like 75-80% of what it's supposed to hold, taking into account what's in the converter). Start engine, let it warm a bit, then manually shift from "P" to "R", to "1-2-3-D", back to park, repeat again, then check dipstick levels. If too low, add a little more and repeat the process again, recheck level. Keep doing this until it's in the correct range. Do NOT overfill.
Not doing this (or worse, installing the torque converter dry) can manifest trans troubles.
Edited by Bushwick
