lmdew Posted January 3, 2017 Share Posted January 3, 2017 I replaced the rear struts on my 06 Forester with a set of KYB's I had from a 98-04 Forester. The top hats and springs were different but the 00 KBY struts I had bolted right in, springs, and top hats. Brake line support brackets had to be modified a bit for the lines to go in but they worked great. I kept the 06 Springs and top hats if I ever need them. Quote Link to comment Share on other sites More sharing options...
wtdash Posted January 3, 2017 Share Posted January 3, 2017 Larry, Please explain What was different about the '06 top hats? The '03-'08 should all be the same - other than the XT (turbo) having different ground clearance- which could just be different springs?? I did see this that '06 had more ground clearance: http://www.cars101.com/subaru/forester/forester2006.html#specs thanks Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 4, 2017 Author Share Posted January 4, 2017 The 06 had a D shaped top hat and a tapered spring. The mounting studs were the same spacing. Seems too work great. Larry Quote Link to comment Share on other sites More sharing options...
