Sticking gas pedal
Sticking Gas Pedal
14 replies to this topic
#1 nitpikker247
nitpikker247
    Member
  • PipPip
  • 29 posts
  • Dunellen, NJ 08812
Posted 14 January 2018 - 07:23 PM
It sticks especially in the Cold weather. But after a couple of depresses of the pedal, it goes away.
Its starts all over again the next day.
#2 montana tom
montana tom
    Subaru Nut
  • 533 posts
  • trout creek montana
Posted 14 January 2018 - 07:31 PM
Well .. what is it ?   year ?  Model? color ?  air pressure ?
#3 gbhrps
gbhrps
    20 Year Subie Fan
  • 1,103 posts
  • Canada
Posted 14 January 2018 - 08:03 PM
nitpikker247,
This isn't being nitpikky, but knowing what year, model, mileage and options (manual/automatic) often narrows down where we need to start when diagnosing an issue. Until we have that, its a crap shoot.
#4 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,973 posts
  • Charlottesburg, VA
Posted 14 January 2018 - 08:17 PM
Does it stick open or closed?
#5 impostor
impostor
    New User
  • PipPipPip
  • 74 posts
  • Omaha
Posted 16 January 2018 - 07:40 PM
Clean your throttle body.
#6 nitpikker247
nitpikker247
    Member
  • PipPip
  • 29 posts
Posted 20 January 2018 - 08:18 PM
#7 nitpikker247
nitpikker247
    Member
  • PipPip
  • 29 posts
Posted 20 January 2018 - 08:20 PM
2005 Baja sport. Auto Trans.
Pedal Only Sticks from Idle position.
#8 nitpikker247
nitpikker247
    Member
  • PipPip
  • 29 posts
Posted 20 January 2018 - 08:21 PM
#9 nitpikker247
nitpikker247
    Member
  • PipPip
  • 29 posts
Posted 20 January 2018 - 08:24 PM
I sprayed silicone on it.
I will be more thorough on the next try.
Thanks
#10 golucky66
golucky66
    Subaru Nut
  • 568 posts
  • Barkhamsted Connecticut
Posted 20 January 2018 - 08:53 PM
The Baja's all have electrical throttle body's. So if the throttle body was sticking it would have no effect on the pedal.
As for the pedal. Get down there and spray some lube in there. It's possible it's sticking from age. Then after you spray it down, work the pedal back and forth with the car off so you can move it the full travel.
#11 nitpikker247
nitpikker247
    Member
  • PipPip
  • 29 posts
Posted 21 January 2018 - 10:34 AM
Thank you!
I will Try that.
#12 impostor
impostor
    New User
  • PipPipPip
  • 74 posts
  • Omaha
Posted 22 January 2018 - 05:55 PM
The n/a baja is drive by cable.  The 255 was the beginning of drive by wire.
Edited by impostor, 22 January 2018 - 05:58 PM.
#13 golucky66
golucky66
    Subaru Nut
  • 568 posts
Posted 22 January 2018 - 07:19 PM
You're right. My apologies.
Didn't realize the NA's didn't get the updated throttle bodies.
#14 nitpikker247
nitpikker247
    Member
  • PipPip
  • 29 posts
Posted 23 January 2018 - 11:10 AM
#15 kamesama980
kamesama980
    Advanced Member
  • PipPipPip
  • 70 posts
  • Columbus, IN
Posted 24 January 2018 - 01:07 PM
the 03 baja has a throttle cable (EJ251) later n/a models got the DBW EJ253. all turbos are DBW (EJ255?). That's why I got an 03 NA and not newer or turbo.
as for fixing the sticking, make sure there isn't a crack in the housing and then use a dry lube. don't use graphite because it could migrate into the electronics.
Edited by kamesama980, 24 January 2018 - 01:09 PM.
