gilty Posted January 29, 2018 Share Posted January 29, 2018 1998 Forester replaced engine with similar 2.5 dual cam. Now the parking lights stay on, related? I unplugged the multi function head light, turn signal, dimmer switch on the left of steering wheel but lights still on. Any suggestions for where to look next. I have been disconnecting the battery if left for more than a day, but that gets old. Also have a stumbling idle and sometime it dies when waiting for a light. Fuel filters? Injectors? spark plugs? The plugs on this motor are a pain to get to. Quote Link to comment Share on other sites More sharing options...
montana tom Posted January 29, 2018 Share Posted January 29, 2018 Parking lights are most likely on because somebody... accidentally hit the virgin switch on top of the steering wheel... Small flipper switch , if you see the red line its on. Quote Link to comment Share on other sites More sharing options...
montana tom Posted January 29, 2018 Share Posted January 29, 2018 NGK spark plugs and NGK plug wires, New air filter, new fuel filter. Any codes on the ecm? check engine light on ? All the tune up parts can be found cheaply at rock auto. Quote Link to comment Share on other sites More sharing options...
gilty Posted January 29, 2018 Author Share Posted January 29, 2018 Yes it was the switch on the steering wheel. Thank you. I have lived this problem before but forgot this subaru quark. Will work on the idle next. No codes or check engine light on, which seems weird. Usually any hic up and that flipping light goes off, but not now. Maybe I should be happy with that. 1 Quote Link to comment Share on other sites More sharing options...
montana tom Posted January 29, 2018 Share Posted January 29, 2018 On a second gen outback with the 2.5 sohc motor, you remove the washer fluid tank on the drivers side and part of the air intake on the pass side. to access the spark plugs .Not sure if forester is the same. Is your 98 A 2.5 4 cam motor? You called it a dual cam... Not even sure if they put the 4 cam motor in the forester lineup. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted January 29, 2018 Share Posted January 29, 2018 On a second gen outback with the 2.5 sohc motor, you remove the washer fluid tank on the drivers side and part of the air intake on the pass side. to access the spark plugs .Not sure if forester is the same. Is your 98 A 2.5 4 cam motor? You called it a dual cam... Not even sure if they put the 4 cam motor in the forester lineup. Yes his 98 has the DOHC 2.5 (EJ25D) Should have replaced it with a 2.2 but anyhow.... My guess is the spark plugs and/or there is an air leak between MAF and throttle. 1 Quote Link to comment Share on other sites More sharing options...
rocketman Posted January 31, 2018 Share Posted January 31, 2018 I have 98 forester and found it easier to replace plugs from under car,however I have since installed 2.2 engine with nice easy plugs on top. Quote Link to comment Share on other sites More sharing options...
brus brother Posted January 31, 2018 Share Posted January 31, 2018 Yes it was the switch on the steering wheel. Thank you. I have lived this problem before but forgot this subaru quark. Will work on the idle next. No codes or check engine light on, which seems weird. Usually any hic up and that flipping light goes off, but not now. Maybe I should be happy with that. Subaru techs refer to this as the battery kill switch as it kills many a battery! Quote Link to comment Share on other sites More sharing options...
