What Works?
8 replies to this topic
#1 Bill90Loyale
Bill90Loyale
    Subaru Fanatic!
  • 423 posts
Posted 12 August 2004 - 09:44 AM
I'd be interested to hear from anyone who has replaced their:
1. Purge Control Solenoid
2. EGR Solenoid
3. Idle Air Control Valve
4. Thermosensor (sends signal to ECM - not the water temp sending unit to guage); and/or
5. Throttle Position Sensor (TPS).
What I'd be interested to hear are any observations about what good things happened or didn't happen when you replaced it, and any tips or suggestions.
Thanks in advance.
#2 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 12 August 2004 - 01:55 PM
why would you be replaceing them? is there a problem you are looking to address?
they are simple items to change but its the old saying if it aint broke dont fix it.
#3 Bill90Loyale
Bill90Loyale
    Subaru Fanatic!
  • 423 posts
Posted 12 August 2004 - 02:39 PM
Rallyruss-
Good point. I've been showing codes 34 and 35 (egr and purge solenoids) for a while. I'll be cleaning the connections and futzing around with my multimeter one of these days to try to see if the solenoids are really shot.
This is more of a long-term thing. I'm (perhaps mistakenly) assuming that all these electrical parts will eventually crap out. For anyone who has:
a. Confirmed that one of these solenoid/senders was actually dead; and
b. Replaced it with a known good one...
I'm interested to know if any of these sensors, when replaced, result in clearly improved engine performance, or if it's one of those exercises in futility.
#4 the_bard
the_bard
    Upstate NY'er
  • 941 posts
  • Rexford, NY
Posted 12 August 2004 - 09:36 PM
My ECU was throwing a code 35, if'n I remember the code right, and I replaced my PCS. It was extremely easy to swap out, cheap (picked it up from a junkyard). Resistance 'cross the terminals was supposed to be 31.9 - 39.9 ohms, and I was getting 60+.
Performance-wise... it idles a lot better now, and I believe the gas mileage improved. Beyond that, not much.
On the bright side, that d**n check engine light went off. Annoyance.
#5 baccaruda
baccaruda
    YOUR FAVORITE MOM
  • Moderator
  • 6,949 posts
  • SpoVegas, WA
Posted 12 August 2004 - 09:44 PM
check the wiring harness where it plugs to the sensor, too. sometimes the wires can separate from the clips and such too.
#6 the_bard
the_bard
    Upstate NY'er
  • 941 posts
  • Rexford, NY
Posted 12 August 2004 - 09:55 PM
Of course, if you get tired of dealing with it, you could always sell it to me :brow:.
Or, when I finally replace my Loyale in a month or so, you could take a drive down here and grab whatever parts you need off of my Loyale, if you'd like.
#7 Bill90Loyale
Bill90Loyale
    Subaru Fanatic!
  • 423 posts
Posted 17 August 2004 - 10:02 AM
Thank you Bard, Rallyruss and Baccaruda. Checked resistance on both purge control and Egr solenoids. About 115 ohms each. Too high. Idle air control valve checked out ok.
Anyone have used (and working) purge control and egr solenoids for sale?
#8 MilesFox
MilesFox
    Catch this Fox!
  • 10,685 posts
  • Madison/Milwaukee, WI
Posted 17 August 2004 - 01:14 PM
i have had the most luck with the THROTTLE POSITION SENSOR, on 3 cars it made a big improvement
#9 Bill90Loyale
Bill90Loyale
    Subaru Fanatic!
  • 423 posts
Posted 18 August 2004 - 09:26 AM
Miles-
Thanks. Are you talking cleaning electrical contacts? Removing the TPS and replacing with J/Y version? Remove replace with new OEM? And positioning of the TPS on installation is important right?
Bill
