craigusoz Posted November 27, 2004 Share Posted November 27, 2004 Hi all - I'm about to lift the engine out of a Legacy front cut that I bought - the engine is going into my Vortex. Just a question for those that have done it before - is it OK to just use the lift point on the air conditioner bracket to lift the engine? That gives an off-centre lift for one thing. I can't see another lift point anywhere towards the rear of the engine. Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted November 27, 2004 Share Posted November 27, 2004 Hi all - I'm about to lift the engine out of a Legacy front cut that I bought - the engine is going into my Vortex. Just a question for those that have done it before - is it OK to just use the lift point on the air conditioner bracket to lift the engine? That gives an off-centre lift for one thing. I can't see another lift point anywhere towards the rear of the engine. First, for us US blokes, what is a Vortex? As for the rear lifting point, are you removing it with the tranny still attached? There is a lifting point on the tranny, the tab is usually bent over, but it is still there. When lifting just the engine, I use a small metal bracket that is located near the turbo, or sometimes I just hook up to the turbo itself. Being the technical person that I am, I can't pass this up, if you have a DOHC EJ20 (I've never seen a SOHC EJ20) then the engine number is an EJ20G, the 'T' was used only on the SOHC engines (ie EA82T and EJ22T). Quote Link to comment Share on other sites More sharing options...
Qman Posted November 27, 2004 Share Posted November 27, 2004 Vortex = XT Sounds like a fun and powerful transplant. Quote Link to comment Share on other sites More sharing options...
craigusoz Posted December 4, 2004 Author Share Posted December 4, 2004 Thanks guys. It turned out I couldn't seperate the transmission from the engine while it was still in the frontcut anyway (some corrosion on the dowels), so I just pulled the whole assembly, using the pitching stopper bracket for the rear lift point. Quote Link to comment Share on other sites More sharing options...
