spark plug upgrade ?
8 replies to this topic
#1 robb1
robb1
    USMB Regular
  • PipPipPip
  • 44 posts
  • syracuse
Posted 02 December 2004 - 10:34 AM
Time for a spark plug change on a 98 impreza 2.2 outback sport.
Should i put the same type of oem plug back in or.....
does anyone have a suggestion on a upgraded plug for better
performance or better gas mileage?
Thanks for all relpy's !
Robb
#2 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 02 December 2004 - 01:27 PM
NGK V-power Copper. Alot of people on the board use them and reccomend them. Granted platinum is better but doesn't last as long as the coppers.
Hope this helps.
#3 Setright
Setright
    Elite Master of the Subaru
  • 3,174 posts
  • Denmark
Posted 02 December 2004 - 01:33 PM
First off, after years of Sube experience many of us - back me up guys! - have come to the conclusion that NGK Spark plugs are the best for Subaru engines. "V- Power" or "V-groove" is one step from the bottom and work very well, and are not expensive.
If you feel like upgrading, NGK do make Iridium plugs that fit Sube engines, in fact some models (mainly Turbos) use these as factory fit.
Stay away from fancy multiple-ground plugs.
#4 PAezb
PAezb
    Subaru Fanatic!
  • 407 posts
  • USA
Posted 02 December 2004 - 01:35 PM
Hope this helps.
hmmmm, isn't it coppers don't last as long as platinums?
coppers typically should be checked/replaced at 30K
platinums at 60K and Iridiums at 120K.
I would concur with the NGK brand for Subaru's, copper or the platinums. Subaru mechanics I've spoken to mostly state to stay with NGK for best performance.
Anyone else?
#5 vrg3
vrg3
    USMB Regular
  • PipPipPip
  • 36 posts
  • Ithaca, NY at times and McLean, VA at other times
Posted 02 December 2004 - 02:02 PM
Yeah, copper's a better conductor than platinum, but platinum lasts a lot longer.
In my opinion, the extended service interval of platinum plugs is not really an advantage, since I think you should be removing your plugs more often than that just to check them and to make sure they don't fuse to the heads.
#6 frag
frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 02 December 2004 - 02:18 PM
Maybe I'm wrong but I think platinium and iridium NGK plugs are copper cored and it's only the tip that's platinum or iridium. Moreover, the very small diameter of the plat or iridium tip makes for less voltage to get a spark. thus better cold starting is one of the advantages.
#7 rweddy
rweddy
    1000+ Super USER!
  • 1,408 posts
  • Castle Rock, CO
Posted 02 December 2004 - 04:13 PM
I agree! Stick with NGK.
#8 coloradosubarules
coloradosubarules
    Banned
  • Banned
  • 870 posts
  • Port St. Lucie
Posted 02 December 2004 - 11:11 PM
Ok ok...someone told me otherwise on the board. I can only repeat what I was told.
#9 subyroo
subyroo
    Subaru Master
  • 1,893 posts
  • Caloundra - Australia
Posted 04 December 2004 - 09:53 PM
A lot of Aussie guys I know use the NGK Iridium's on all model Subaru's right back to the old models and love 'em. One of my friends has 90,000kms (55,900 miles) on his and says they are as good as new when he had them tested.
