Reasonable Compression for 86 GL
4 replies to this topic
#1 willyburns
willyburns
    New User
  • PipPip
  • 10 posts
  • Boise
Posted 06 December 2004 - 12:21 AM
Greetings All.
I'm looking to buy a subaru, and I am going to compression test it. What is an acceptable range for an 86 GL no turbo with 150k. Obviously, I will be on the lookout for even compression accross all the cylinders, but I want to know how tired this thing is. 125-130 psi??
What is the factory spec. on a new motor?
Thanks!
#2 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 06 December 2004 - 01:17 AM
Ideally, it would be at 150 psi or a little bit more in all 4 cylinders.
But the most important thing to check for is consistency between all 4 cylinders. For example, if you have one cylinder down considerably, you might have a burnt valve or a damaged cam lobe or incorrect cam timing. If you have two cylinders down on one side of the engine, that's a strong indication of a blown headgasket. Stuff like that.
#3 willyburns
willyburns
    New User
  • PipPip
  • 10 posts
  • Boise
Posted 06 December 2004 - 01:30 AM
Thanks very much.
#4 Petersubaru
Petersubaru
    1000+ Super USER!
  • 1,091 posts
  • Sarnia Canada
Posted 06 December 2004 - 11:57 AM
For what ever it is worth...Factory specs for a new N/A EA82 motor is 168psi...my 86 with 200,000mi on it has between 155-160...but then again this car I have had since near new/mostly highway miles/oil changed every 3000mi.
Thanks![/QUOTE
#5 subynut
subynut
    EJ Powa!
  • 1,422 posts
  • Sierra Vista, AZ
Posted 06 December 2004 - 07:36 PM
My Suby (carb block, SPFI pistons, decked heads) runs between 145-150ish. My sisters' Subys (bone stock, carbed, around 150k miles) run around 120-130 psi.
