96 Legacy antifreeze leak...?
2 replies to this topic
#1 bgambino
bgambino
    Subaru Nut
  • 542 posts
  • new york
Posted 12 December 2004 - 09:14 PM
hey guys....
I was under the car today and I notice some antifreeze leaking...it appears that the thermostat is under the engine now? as the lower radiator hose seems to connect to what appears to be the thermostat housing...correct?
Is the unit above (connected to)the housing the water pump?
It seems the leak is coming from the gasket between this and the block.
Whats involved in replacing (assuming thats what it is)? With 110K on it, I have to assume the T belts are probably due (are these 50-60k like the loyales?)
#2 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 13 December 2004 - 09:31 AM
Yes you are due timing belt change, I was able to do my 97 Legacy wagon with the help of Haynes manuel. The hardest part for me was getting the crank pully bolt to break loose. The T-stat is there were you thought.
#3 lmdew
lmdew
    _______
  • 2,366 posts
  • Colorado Springs
Posted 13 December 2004 - 09:19 PM
Yep, the water pump is leaking (there is a weap hole that you can not see with the pump installed. It results in the leak you described.
Do the hoses and belts, T-belt, water pump, cam & crank seal, tighten the oil pump cover screws, and carefully check the pulley bearings and tensionner for wear and indications of failure.
Make sure you fully bleed the coolant system when you go back together to get all of the air out.
www.1stsubaruparts.com is a good source of parts.
