Forester Transmission problem?
4 replies to this topic
#1 ron2368
ron2368
    USMB Regular
  • 125 posts
  • Lancaster PA
Posted 31 August 2003 - 12:09 PM
I have a 99 Forester, after a 30 minute highway drive with the a/c on I see lots of smoke from the engine compartment .
To shorten the story I am very sure it came from 2 little vent hoses on top of the auto transmission . The catalytic converter is just below so it was burning the atf = lots of smoke.
I did not notice any shifting problems during the drive. I had the fluid and filter replaced 9 months ago and have not added any atf during that time so it can't be overfilled.
Any ideas, other than this time I have never noticed it before. Thank you for any assistance.
#2 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,986 posts
  • Texas
Posted 31 August 2003 - 01:08 PM
I don't know if I can help, but others may be able to if you give us some more info.
You say it couldn't have been overfilled 9 months ago. Did you look?
Also, what is the level now(after the 'burp')?
Did you get a CEL or an AT Temp light.
Did you check any other fluids to be sure that's where the smoke came from?
Carl
1 Lucky Texan
#3 ron2368
ron2368
    USMB Regular
  • 125 posts
  • Lancaster PA
Posted 31 August 2003 - 07:51 PM
Since the change I have checked the atf and it always was at the proper line.
When I looked at the area after the smoking incident I could see a trail of oil residue from below the vents down to the trans area above the converter so I am sure that was the cause. There were 2 drips of trans fluid in the garage below that area also.
When I drove home that night( return trip) there was no smoking, also the area under the car is always clean, never any drips, so I am assuming that this never happened before.
#4 1 Lucky Texan
1 Lucky Texan
  • 7,986 posts
  • Texas
Posted 31 August 2003 - 08:44 PM
Could you or a family member have driven through deep water recently?
Here's a WAG - If the tranny gets cooled off by being submerged in deep water, contraction can suck water inside that could vaporize at operating temp causing a 'geyser' like effect - um I GUESS.
Carl
1 Lucky Texan
#5 ron2368
ron2368
    USMB Regular
  • 125 posts
  • Lancaster PA
Posted 01 September 2003 - 06:23 PM
Sorry, no floods not even any heavy rain. The atf was low about a pint. I dont know much more about this problem.
Maybe I can get longer hoses and run them into some receptacle so I can see if or how much fluid I am losing.:cornfuzz:
