Timing belt question/TDC question
3 replies to this topic
#1 CMohan
CMohan
    New User
  • PipPip
  • 24 posts
  • Portsmouth
Posted 07 June 2005 - 07:33 AM
Hi everyone...I just had a quick question about taking out the timing belt to get to the oil pump...The haynes manuel says you need to put the engine at top dead center....is this procedure necessary and, if so, any advise on how to do this easily.....
My car is a 96' Legacy 2.5 DOHC.....thanks for any help I receive.
- Chris
#2 tomson1355
tomson1355
    USMB is life!
  • 155 posts
  • Upstate
Posted 07 June 2005 - 08:35 AM
You want the crank sprocket so the mark is at 12 o'clock. You can rotate the engine with the crank bolt once you have the TB exposed. In this position the two left side cams are opening valves. In this position, if they move when you take the belt off, they won't damage any internals. When replacing the belt, those two cams need to be rotated in the correct direction, again so as not to cause any interference inside.
#3 lmdew
lmdew
    _______
  • 3,727 posts
  • Colorado Springs
Posted 07 June 2005 - 05:52 PM
It's the mark on the back of the gear tab not the arrow on the front of the gear. Lot's of folks mix these up.
#4 Storm
Storm
    USMB is life!
  • 143 posts
  • NEOhio
Posted 09 June 2005 - 01:33 AM
The triangle mark is what you want lined up to remove the belt. The hashmark on the tooth is lined up for installation.
