Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
write up for six lug swap?
#1
Posted 15 July 2005 - 08:09 AM
Thanks
#2
Posted 15 July 2005 - 10:03 AM
#3
Posted 15 July 2005 - 10:11 AM
http://www.ultimates...=6 lug template
Here ya go, hope that helps.
#4
Posted 15 July 2005 - 10:35 AM
I think there is a template that some made up and posted a while ago
Good thread
Here is the answer to the question about seating your studs properly:
You don't want to countersink them. Spotfacing is the optimum approach. It will maintain a flat surface for the studs to sit into.
Ken
#5
Posted 15 July 2005 - 11:00 AM
#6
Posted 15 July 2005 - 12:58 PM
What is spotfacing? I called the machine shop and told him that spotfacing would be the best way, but he doesn't know what that means. Neither do I.
SPOT-FACING A machining process in which the area around a hole is milled to smooth, flat surface by application of a rotating tool with cutting edges on its end or face.
... look where the head of the stud mates to the back of your hub. It's not a flat surface... you mill it down to a flat surface.
#7
Posted 15 July 2005 - 01:09 PM
the template makes me nervous, how can you center it on the wheel? you gotta use a wheel as your template. but you cant just take a drill bit that fits in the hole and hope its centered either.
i had to build a special tool to center/drill them
send them to me. do you have rear discs? if so, its alot easier.
