Whiteline offers swaybars...
8 replies to this topic
#1 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 29 July 2005 - 07:59 PM
FRONT for the Gen3(EA82) Leone/Loyale/XT....
20MM.
Retail on it should be around $150...and it comes with the swaybar bushings.
:slobber: I might go for that...as I only have a 19mm on it now.
#2 TheSubaruJunkie
TheSubaruJunkie
    Subaru Sober since 2010 :(
  • 1,907 posts
  • Sacramento
Posted 29 July 2005 - 08:02 PM
Cant you get 20mm from XT6's?
-Brian
#3 JWX
JWX
    Lonely driver
  • 3,072 posts
  • Atlanta
Posted 30 July 2005 - 02:42 AM
thats what I was just thinking, but the 20mm whiteline should be better than a factory one I'm thinking. and since they offer a bar they should be able to bend us up any size we want. 30mm here I come :)
#4 gravelRX
gravelRX
    Driven with both feet.
  • 885 posts
  • Roanoke, VA
Posted 30 July 2005 - 11:42 AM
How does your car handle now? What are you trying to accomplish by mounting a bigger front bar?
Jay
#5 tizzle
tizzle
    Subaru Nut
  • 594 posts
  • Bellingham
Posted 30 July 2005 - 12:54 PM
One of the things that bothers me about the RX is too much body roll. It definitely needs a larger rear sway bar. Hopefully the bushings I ordered will make a good overall difference too. wouldn't 30mm be a little excessive, and create oversteer problems. I'm just thinking the rear sway on my legacy is set at 21 or 22 now, and creates a mild, controllable oversteer
#6 gravelRX
gravelRX
  • 885 posts
  • Roanoke, VA
Posted 30 July 2005 - 03:17 PM
Will is talking about front sway bars.
JWX are you saying put a bigger bar on the front than on the rear?
Cut and Paste from a post I made in 2003
Sway bars are put on a car to limit the roll angle of the car during lateral acceleration and deceleration.
Since tires develop the maximum amount of traction when they are perpendicular to the ground (and the tread is parallel) that’s what you’re going after. Subarus are notorious for little to no usable camber adjustment. It has an innate inability to keep the outside front tire perpendicular to the ground during corners. In fact, they are forced to positive camber setting when pushed hard. Understeer.
Standard Subaru engineering.
It’s also a safeguard when Japanese manufacturers brought over cars to the US. The average driver can control understeer, not oversteer
. Domestic cars too, for that matter.
Sway bars increase roll stiffness and they are, by far, the cheapest and easiest modification to increase roll stiffness on a Subaru. When you turn your car, one wheel will be up because of compression and one will be drooping down. The sway bars limit the roll angle of the car by using torsional stiffness to resist one wheel going up and the other going down.
If a car has understeer, too much of the load is on the front outside tire. By increasing the size and effectiveness of the REAR swaybar, some of the load can be transferred during cornering to the outside rear tire.
This will decrease the load on the front tires and make the car handle in a more neutral fashion. The very opposite is applied when increasing the front.
The stiffness of a swaybar increases very quicky as its diameter is increased. The stiffness is a function of the diameter to the fourth power.
For example: A 1 ¼” diameter swaybar is 2.44 times as stiff as a 1” swaybar.
A 1mm change will change the understeering characteristic of the wagon enough to notice. Especially in sharp, on throttle turns. Let’s not forget about weight transfer. Get that long wheelbase car nose high in acceleration, with the weight transferred to the rear, then cut the wheel. Push.
Panic, jump on the brakes, overload the fronts, transfer weight off the rear. Push.
A rear swaybar will help balance out the weight in a lateral manuever by not letting the trailing wheel get too high and thus not help with traction. It will help take the load off the fronts, too. Jay
Will, why would you want that big of a swaybar on the front? What's the rest of your set-up and how does it accomodate such a big bar in the front without adversely affecting turn in? Or where you just surprised that Whiteline made anything for theses models?
Brian, IIRC the 20mm bar is from the rear of the XT6.
Tizzle, If you lower the roll center of these cars it has more of an effect on the body motion than doing anything else. Shorter springs with higher ratios and appropriate rebound and damping combined with correct swaybars would be the way to go.
Regards,
Jay
#7 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 30 July 2005 - 06:22 PM
i am exploring options on sway bars. Ultimately I will have 25~27MM front and rear bars. Yes I was VERY suprised to see that whiteline offered ANYTHING for the Leone's.
Stompy (ESP prepped STi running out of Atltanta GA thru the likes of Joel Ferhman and Tommy Pilliam (sp?) is running 40mm front and unknown rear (tho it is known that the rear is OVER 35MM)...along with some crazy springs rates...12k front and 19k rear on 285/30/18 Khumo V710's.
#8 JWX
JWX
    Lonely driver
  • 3,072 posts
  • Atlanta
Posted 30 July 2005 - 06:44 PM
I was just kidding, and from what I've heard stompy doesn't wear a rear sway bar.
#9 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 31 July 2005 - 08:19 AM
when it didnt and had the wrong size....inside rear wheel lift. I was talkign to Joel at the Peru Tour...asked him the fix for that as the car was PLANTED...he said he got the F/R swaybar setup correct on it. :banana:
