long time owner first time writer
9 replies to this topic
#1 my83subaru
my83subaru
    New User
  • PipPip
  • 10 posts
  • 98390
Posted 02 August 2005 - 11:25 AM
I have an 83 gl wgn that I bought new. 205k thank you. I would like to know if an engine and trans from an 85 wgn will bolt in. Or what years will fit my 83. I'm very interested in keeping this car as it has been very good to me. thanks for your help
keep them running down the road.
Mike
#2 Scoobywagon
Scoobywagon
    Evil Genius (tm) for Hire
  • 1,044 posts
  • Bremerton-like
Posted 02 August 2005 - 12:52 PM
Hi there and welcome to the board.
Your 83 wagon has an EA-81 engine. It is a 1.8L OHV engine. The 85, on the other hand, has an EA-82 engine. It is a 1.8L OHC engine. As such, it is SIGNIFICANTLY wider than your current engine. You may have to do some sqeezing, but it should bolt up without a problem. Then the question arises: Is your 85 injected or carbed? Obvoiusly, injection entails a lot more parts swapping than another carbed engine.
For the most direct fit, find a wagon built between 81 and 84, a hatchback built between 81 and 88(I think?) or a Brat built between 82 and 88.
#3 my83subaru
my83subaru
    New User
  • PipPip
  • 10 posts
  • 98390
Posted 03 August 2005 - 10:21 PM
thanks scoobywagan. I will check that out.
#4 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 03 August 2005 - 10:35 PM
What part of Sumner/Bonney Lake are you in?
The direct applications would be 80-84 wagon, sedan and coupes. 81-89 hatchbacks and 82-87 Brats. Many people have swapped in other engines but you are talking major modifications. Just depends on what you want to end up with.
#5 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 04 August 2005 - 03:03 AM
85 wagon motor will work. use the carb and intake from the 85 with its motor. connect anything theat will match such as electrical connections
use the flywheel from the ea81, drill out the holes for an ea82 flywheel bolts
if the 83 was FWD 5sd and the 85 was fwd 5spd the clutches would fot the same, use the ea82 flywheel
in any other case you will scribe the timing belt marks to the ea81 flywheel.
the bolts are m10 x 1.0 thread
the motor will fit just right. i recommend removint the inner and outer timing belt covers for future service
remove the disty before installation to clear the master cylinder
the hill holder will have to be re-located(bend the lines)
#6 my83subaru
my83subaru
    New User
  • PipPip
  • 10 posts
  • 98390
Posted 13 January 2006 - 11:52 AM
I live in the valley. Right of hwy just the Puyallup river.
#7 my83subaru
my83subaru
    New User
  • PipPip
  • 10 posts
  • 98390
Posted 13 January 2006 - 11:53 AM
Sorry for not writting sooner. but I live right off the hiway, just past the Puyallup river.
#8 my83subaru
my83subaru
    New User
  • PipPip
  • 10 posts
  • 98390
Posted 13 January 2006 - 12:01 PM
Mike
I have decided to keep the car engine in there. I do have a tech. question...
Is it normal for the engine to lose oil pressure when going up a hill.
If I let up on the gas, the press wants to climb, or so it is indicated.
Is it time to change the oil pump,and or is it time to change other things also while I'm at it.
Hope you all are doing good with your other Subs.....
Shades are on with all of this rain in the NW. Thanks
#9 my83subaru
my83subaru
    New User
  • PipPip
  • 10 posts
  • 98390
Posted 13 January 2006 - 03:10 PM
Mike
I would like to find an EA-81 engine for my 83 subaru GL.
Do you have one that I can buy?
thanks
#10 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 13 January 2006 - 05:08 PM
If you are looking for a rebuilt engine for it, you should contact CCRinc. I just got a rebuilt EA82 for my wagon from them, and they are a delight to deal with.
You can get ahold of her by PM. Her board name is CCRinc
