top lights
7 replies to this topic
#1 stu's fleet
stu's fleet
    USMB Regular
  • PipPipPip
  • 45 posts
  • Bethany conn
Posted 17 September 2005 - 07:23 PM
on my 06 baja how do i change my top light's from going on by my e brake to going on by dash switch i want to use them when i go on a trail any modifactions to make it work
#2 subie94
subie94
    Major Subaru Fan..
  • 1,583 posts
  • Epsom,N.H.
Posted 17 September 2005 - 08:59 PM
my guess would be to disconnect the top light from the factory wires an run new wires to what ever switch you put in.
i take it your talking about the third brake light,right?
that's how i'd do it.
#3 stu's fleet
stu's fleet
    USMB Regular
  • PipPipPip
  • 45 posts
  • Bethany conn
Posted 17 September 2005 - 09:07 PM
no the top driving lights
#4 subie94
subie94
    Major Subaru Fan..
  • 1,583 posts
  • Epsom,N.H.
Posted 17 September 2005 - 09:11 PM
Hmmm...an they go on with your e-brake? that's a first for me.
well you could find out were at the e-brake the switch is then re-route the wiring to where ever you put the switch on the dash.
did that help??
#5 stu's fleet
stu's fleet
    USMB Regular
  • PipPipPip
  • 45 posts
  • Bethany conn
Posted 17 September 2005 - 09:34 PM
yea there is a switch on dash but it will only work with e brake it it is up if i lock the e brake switch the brake light will be on too
#6 subie94
subie94
    Major Subaru Fan..
  • 1,583 posts
  • Epsom,N.H.
Posted 17 September 2005 - 09:49 PM
maybe there's a way you could by pass the e-brake switch so there's power going to the switch on the dash all the time.
have you gained access to where the e-brake switch is.how many wires is leaveing the e-brake switch.probably one wire going to dash switch and one going to the light on the guage panel.if that's the case then jump the e-brake switch with a splice connection and hook it to the wire going to the dash switch.
(maybe?)
#7 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 17 September 2005 - 11:23 PM
Just rewire them from scratch with a switch and a relay. Way less time than figuring out how to modify the factory wiring.
Just my two cents.
#8 Numbchux
Numbchux
    EJ conversion addict
  • 6,648 posts
  • Saginaw, MN
Posted 18 September 2005 - 09:32 AM
Just my two cents.
could be, I'd say check it out, pull off the plastic moulding around the ebrake handle, and see if you can figure it out. otherwise you might just want to find the origional relay/switch and run a new wire straight from the battery to the + side of the relay, it'll always be on, but just make sure you flip the switch off when you're not using them
