legacy dome light
9 replies to this topic
#1 cyberfire
cyberfire
    New User
  • PipPip
  • 17 posts
  • Santiago
Posted 02 January 2006 - 02:16 PM
Hi,
I have a 96 Legacy and I have to change the dome light every 2 months (if not every month) I cant seem to find out why it burns out.
Any idea?
Thanks.
#2 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 02 January 2006 - 02:33 PM
try finding a lamp made by OSRAM (Sylvainia)
or
Convert to white LEDs
(costly but should last forever)
#3 cyberfire
cyberfire
    New User
  • PipPip
  • 17 posts
  • Santiago
Posted 02 January 2006 - 02:40 PM
Ok, so your saying that is just a bulb problem, I sould not try looking for a more complex problem?
G.
#4 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 02 January 2006 - 02:52 PM
G
affirmative
if it were a voltage problem you would be burning out
more lamps than just this one
#5 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 02 January 2006 - 04:00 PM
Corroded connections can do it but I would think the dome light should be fine. Would not hurt to clean them.
#6 Suzam
Suzam
    1000+ Super USER!
  • 1,148 posts
  • Wilmington, Delaware
Posted 02 January 2006 - 07:21 PM
Have you bought the replacements form the same place each time?
If so try a different source, I had a string of brake/tailights that burned out every 2-3 months and went through 3 double packs (in 8 months), then I happened to purchase some at a different store, hasn't burned out yet after 2 years.
#7 OswaldtheBold
OswaldtheBold
    New User
  • PipPip
  • 23 posts
  • Grand Junction
Posted 02 January 2006 - 09:25 PM
I strongly recommend replacing the bulb with the LED unit from George at http://taskled.com. I have them in my Legacy and my Landcruisers. Major improvement.
#8 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 02 January 2006 - 09:39 PM
very nice idea
but
30 GW's for a dome light?
maybe if.........
#9 nipper
nipper
    Semi Elite Master of the
  • 17,110 posts
  • Long Island NY
Posted 03 January 2006 - 12:09 AM
Just for the hell of it, take a volt meter and see how much voltage is at the contacts with the car running. The only thing i can see blowing out bulbs there is a poor quality bulb, heat, or voltage/current being to high (and that would be a real real real longshot on the begings of an alternator going bad). The only OTHER thing is vibration. Make sure the fixture is tight, as are the sockets.
nipper
#10 cyberfire
cyberfire
    New User
  • PipPip
  • 17 posts
  • Santiago
Posted 03 January 2006 - 06:30 AM
Ok, I will check, clean and buy new bulbs.
Thanks guys.
