dentedfender Posted March 10, 2006 Share Posted March 10, 2006 i just put in a 83 tranny into my 84 gl and the cv's can move up and down and in and out about 1/4 of an inch. One of the techs at my work said it was cuz its probally a dl tranny and those use smaller cv's. Is this true? Also what else could be causing this besides them being diffrent sizes? thanks for the help. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted March 10, 2006 Share Posted March 10, 2006 are you meaning the axle wobblesaround on the tranny stubs? both trannies have 23 spline shafts what part of the axle specifically "moves in and out"? Quote Link to comment Share on other sites More sharing options...
dentedfender Posted March 10, 2006 Author Share Posted March 10, 2006 are you meaning the axle wobblesaround on the tranny stubs? both trannies have 23 spline shafts what part of the axle specifically "moves in and out"? Yes the axle on the tranny stubs. and if you grab the outside peice of the axle that connects to the tranny where you have to put the pin in it will move up and down and in and out. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 10, 2006 Share Posted March 10, 2006 Probably sloppy bearings in the tranny. 83/84 should be identical for the same tranny. And as fas as the stub splines - those are the same for ALL EA81 trannys. Even the auto's and turbo's were the same 23 spline stub. GD Quote Link to comment Share on other sites More sharing options...
